Thinking out of the box here.... but maybe I could just put some beads of weld on the old pin to take up some of the slop? Try and true up the pin a bit with a grinder or something, And reinstall it? I figure my crappy welds would be softer than the OEM metal and not do more damage to the C-Frame?
nanan that will get u head haches...
I´ll tell u of a possible and quite cheap field repair that will last a couple thousand hrs...
First u get the C frame to a shop for repair , line welding and line boring , this shall not take more that 2/3 hours labour ... so inexpensive i think,
Second u buy new pins from aftermarket suplier like "berco" or other alike.
Third u take an inner micrometer and check the frame eye ovalization, if its less than ,2mm out of round u leave it.
If not u have to manually grind the hole close to this number. Then u take measure of the hole ID in X patern and find the average ID. Once u get this nr u have a machine shop to machine a bushing made out of Cromolibdenumnickel stell , known as 4337 , at least in my planet. (this material is common in any machine shop due to machine and hardening properties)
This material has very good hadning properties, it can harden to close to 57 just by hammering on it.
The inner ID of this bushing shall have a clearence of .2mm from the pin OD. And bushing OD the average hole ID plus a interference fit margin, 0,05mm.
This material is hardness 40 when anealed, so u can hammer it in place, to get a good interference fit, lube it , heat up the frame eyes, hamerit cold , up to u when u finish the hammering in it will harden to 50 something at least , but is still possible to gind it manually.
Then u just need to manually round it to fit the pin. once the machine start to be used and the pin start to beat up, the bushing will harden much more, so much that it will last a long time, it will get no less hard than a factory hardened bush.
Of course u can also harden the bushing before installation, but that for pro´s...
thare are many more ways to get the same result, i have been successefull this way...
