Can’t keep it up
COWMATSU
canada
Komatsu pc 200lc5 when I let go of joy stick the main cylinders on the stick drop back to the ground
Vetech63
Oklahoma
COWMATSU
canada
Does this sound like a joy stick problem or do I look farther down the line and where do I look next thanks
uffex
Lincoln UK
Admin
Good day
I suggest there is not so much wrong with your joy stick, more probable the valve where it is connecting or the cylinder is leaking.
Kind regards
Uffex
funwithfuel
Will county Illinois
Mechanic
Feel your cylinder(s) after operating, if they're significantly hotter than the rest of the machine's hydraulics, you probably need to get repacked. You said the stick drops but said both cylinders, so I assume you mean the boom cylinders. If you have a temp gun, you can see which is the warmest, that's gonna be the one to go after. Also check your hydraulic oil return filter, see if you have bits of vinyl and plastic in there. Good luck.
