Need some help with the proper testing procedure to rule out what’s good and bad
2014 t770 at startup have over 500 PSI charge pressure after the machine heats up. It will shoot the error code low charge pressure and shut down if I stop working the machine and rev it all the way back up. It will go up to above 400 and run fine however, if I return it to idle it Drops to blow 200 and shut off
I got a good deal on the machine, knowing that I might have issues
Previous owner had pumps rebuilt, and drive motors replaced. I’m leaning towards pressure but wanna be sure since pulling the engines not going to be fun.
