Sprocket ware
Helirich
Stoughton
I’m wondering if this sprocket is shot?
Here is a pic of the other one for comparison.
Is this something that I should be worried about or just keep an eye on?
Mike85
Ontario
It looks wore out, also looks loose on the housing. It doesn’t have any dirt packed into the seam between the sprocket and the case. I’d be looking for one if it were mine it’s got what looks like one bolt broke off.
stourpaine
Retired mechanic
if you can replace it and get out+ replace the broken bolts .but if you cant do it at this time watch the track tension and operate with some care it will likely run a bit longer
Helirich
Stoughton
Swap over? Do you mean flip over or swap to the other track?
Mine was a rental, so I assume all operators were novice. (I certainly am)
92U 3406
Western Canuckistan
Wrench Bender
If this was a machine I made a living with I'd be budgeting to replace them sooner than later. If this is just an acreage machine that gets used a couple hours a month I would just run it until it starts slipping.
Tones
Ubique
Swap from side to side. No point in throwing out part worn parts, run them to total destruction.
Tugger2
British Columbia
Heres how a set of steel tracks on a 303.5 Cat look when they are on the road to total destruction. I weld the odd crack up in the links and keep em going. The machine only works around home now .PB112913.JPG
Tones
Ubique
Helirich
Stoughton
So the Bobcat service manual has zero advice when to change the sprocket. I checked out the missing bolt. It was not broke off. There was another bolt loose, but the sprocket was tight. I put two new bolts in. I’m probubly going to order one (or two) to keep on hand. This is a personal machine, so I don’t need to worry about making a living if it goes down.
Helirich
Stoughton
Got a new sprocket. It’s a very nice piece. I could put this on my coffee table.
Can't say it looks like it has a lot wider teeth.
Do you think I should be in a rush to get this on? Is it very hard to get the track off?
Vetech63
Oklahoma
If you wait any longer those old teeth will start ripping out your cleats
reganj
Central Ms
I have seen on this board someone used a 2 x 4 to detension the tracks to make it easier to remove tracks, Wish I could point you to a thread but,,,
