It's not just that. The temperature of the outlet is higher than the temperature of the inlet. That ought to be physically impossible.
I thought that maybe you had somehow juxtaposed the two sets of readings and put "inlet" where you meant "outlet" and vice versa. To be clear the inlet to the radiator is the hose from the temperature regulator (thermostat) housing shown by the red arrow and the outlet is the hose from the bottom of the radiator to the water pump shown by the blue arrow. This illustration is from the side looking backwards from the front of the machine.
After the engine has warmed up the red hose should always be significantly hotter than the blue hose.
