Or Bro Nigeria.Bro Nige could be a new screen name
Why all these comments on my reply? I think it is enough. If you have no useful info please don't add reply.Not sure what Captain Manering or Awkright will think of being called Bro.
Don’t tell ‘em yer name Pike!
Bit of English humour lads.
I’m sure the Nige will understand the bits that get lost in translation with our African friends
Makes me smile though.
The scavenge is working efficiently. I don't know if the problem with the manufactury material.Yea I definitely wouldn’t go throwing a transmission pump at it with only 120 hrs. Dealer support?
And yet in an earlier post you stated that you drained 40 litres of oil from the converter housing. On the face of it that indicates the converter housing is not being scavenged correctly.The scavenge is working efficiently.
The dealer has no more solutions. They communicated with CAT and waiting.And yet in an earlier post you stated that you drained 40 litres of oil from the converter housing. On the face of it that indicates the converter housing is not being scavenged correctly.
As per the earlier question from @ahart - what is the dealer saying/doing about the problem.?
Look, First the operator claim was about high trn temp. And by tracing the problem we found that all trn oil drawn and sent to torque and not exit back to trn. So the high temp is result and the engine coolant rises temp in final. We checked hoses, Pipes, TC oil cooler for any plug but found nothing.I believe that this should be a dealer problem not a @Sameh problem to fix.
I am not familiar with this model dozer and don't claim to know anywhere near as much as the other guys help you on this, but this seems very odd to me... how did you come to the fact of overheating... dash temp gauge, service codes?
Does it have trans temp gauge, if so what is it reading? Has that been verified with an IR temp gun on a pipe near the temp sender?
You said earlier that the engine coolant temp is only 83*C.... others have already pointed out that coolant should be a lot hotter if the transmission is overheating. So my thinking is are you sure it is actually overheating and not a bad sender giving a false reading?
This may have already been ruled out and I have missed it in reading though but wanted to ask just in case.
@Sameh you will have to explain this a bit more please?And yet in an earlier post you stated that you drained 40 litres of oil from the converter housing. On the face of it that indicates the converter housing is not being scavenged correctly.
It would seem so but I couldn't find the temps anywhere and that should have been double checked early on I was thinking.I would nearly bet my balls the problem is in the torque converter.
You may not be aware of this but the outlet relief valve for the converter controls the MINIMUM pressure of the oil leaving the converter, not the maximum. I wouldn't worry too mcuh about the inlet pressure at cold startup being up a bit above specification. It may be an indication of something but I would say "not proven" at this point.measure inlet pressure of TC when the oil is cold, it was 30 psi higher than specs.
Oil entering the torque converter has two paths. First is the oil passing through the converter assembly and out via the outlet relief valve to the powertrain cooler. This oil flow is what takes away the tremendous amount of heat generator by torque converter operation. The outlet relief valve maintains the minimum pressure inside the torque converter assembly.I want to know is TC has internal passages between the oil path which rotate the turbine and the TC sump? or what make oil not to drop to sump and complete path to the outlet relief then cooler
TDTO 50What type & grade of oil is in the powertrain system.?
That could be a reason for the high inlet pressure when cold. If you have TDTO 30 available change the oil and try a test with that oil. I was once a big believer in 50 oil in transmissions in hot climates but after a lot of testing I have changed my opinion and would now only recommend to go with 50 in cases of extremely high ambient temperatures - probably over 50 DegC.TDTO 50
No, that is not what I was saying. In the case where a large quantity of oil accumulates in the converter housing for whatever reason the result is that the oil level measured on the transmission dipstick goes down. You found this yourself. If the oil level in the transmission case goes down far enough it can potentially create cavitation in the suction side of the section of the transmission pump (remember that it is a 3-section pump) that supplies the transmission and its controls.According to your words if the torque outlet pressure is low, it will lead to cavitation as it controls the pressure inside torque and the inlet pressure affects only in cold start up. Am I right?
