RLG
I have a gradall g6-42P that pops the ignition fuse when the machine ignition is turned to acc. If i disconnect the purple wire from the top of the fuel shutoff solenoid it won't pop. I have changed the solenoid thinking that could be shorting out and it didn't fix the problem. I've tried backtracking the purple wire to eliminate and replace it directly to the dash but it crosses changes on its way there. the diagrams got a bit confusing. I've also been told the short is in the fuel pump but that doesn't make sense to me. Does anyone know which wire behind the dash would be the one for that part of the circuit or where I could look to bypass that wire?
