cat 259d3 a/c inop
mobile-tech
il
looking for wiring diagram for cat 259d3 serial CW903327
ac inop , full charge , pressure switches check out and freeze switch or t stat in hvac box , have supply power to compressor relay , no ground at relay or signal to relay to energize compressor clutch
thanks
yz558
SW Ohio
Any chance you could share with me as well? Have not installed gauges as I have the machine away form the shop but will be putting gauges on tomorrow.
CW907138
Tyler d4c
Salix Pa
Is the switch on i have to relearn once a year that it has to be on to get ac (im slow at times)
smifwal
kansas city
Last time mine wasn't working there was a small rock blocking the little tubes that let it condensate, worth a look if everything checks out I have a 2021 259D3
yz558
SW Ohio
Found the issue once we started to pull vacuum. Condenser line at the door hinge had a break in it. Picking up a new line Wednesday, pull vacuum for 30 minutes and if all is well recharge and see how she goes.
Thank you all for the assistance.
