Yeah, I will be going through and greasing everything (including all linkages that I can gain access to) and then do all fluid changes. After that, I'll use it a while, listen to what she's telling me she needs and go from there. My machine also has the hand brake, but I need to take a look at it since it isn't holding, but I can't imagine it needs to much repair, perhaps just some adjusting. Mine also wants to "creep" juuuust a tiny bit, (like an inch a second at low-mid idle) but I'm hoping cleaning up the pedal linkages and the pedal shaft will help it out (fingers crossed!) I'm also noticing that is has a hard time shifting between 1, 2 and N. These are my initial findings having just got it, and driven it for 15 minutes collectively. I've been stuck at work just chomping at the bit to explore this thing in further detail!
Future plans will be to convert it to accept any Bobcat Quick Tach attachment, and also run remote/aux hydraulics/electrical up front. Also, I will check my axels to see if there is a date on them as well.
