Hi all wee the repair to the final drive has gone well, no leaks, but what I thought was associated issue obviously isn't
Here's the problem, cold start everything seems to operate as it should 5 mins in and the fun begins, there seems to be an issue with the hydraulics, where I tend to loose hydraulic power, this is not the engine bogging down , the easiest way to describe it , I cannot slew the machine or its incredibly slow MM at a time , if I lower the engine speed back to idle it comes back to life, its the same with the track motors and everything else, This had been going on for a while now and I related it to low oil perhaps due to to the track motor leak , so much for my ideas.
seems that at times under full power it tends to work then just stops , so I need to idle the machine give everything a jiggle on the stick and we can increase power again .
Does anyone have any ideas, its a great little machine a bugger to get into because its so small just wondering what to do next , it has pressure as cold its ok this slow everything down and its ok seems to me a possible relief valve any help would be appreciated, keep on diggin Tommy
