2008 310j
Gravypig
Michigan
mg2361
Pennsylvania
Equipment Mechanic
Solution 77159 is an old solution referencing solenoid identification based on total length of the solenoid (there are 3 sizes) on the parts page. When the parts manual for this model was first set up, they just had part numbers, no reference to Y1, Y2, Y3, etc.. Now when you look at the image above, you see a reference to Y4, 2nd speed.
Gravypig
Michigan
So I replaced y4 solenoid and the codes went away but still no second gear. I have a feeling this is going to be expensive.
Gravypig
Michigan
So I ran the self diagnostic test for the transmission solenoids and everything past.
All other fwd or reverse gears work just fine besides second gear. When in second gear it will some times rolling on its own but acts like it’s just slipping.
Gravypig
Michigan
Any body have a wiring diagram for the transmission. Mainly where the power source comes from for the y4 solenoid
