2014 Bomag MPH600
Columbia SC
2014 Bomag MPH 600
Serial # 1015900860000014
Having a problem with noise on the left side of the milling drum, hydraulic pressure was correct and left side motor was removed and checked for possible,
bad bearing or motor issue none found motor was taken apart by a hydraulic shop and good as well. Our company was told that there is a transmission assembly in the milling drum which is turned by the
motor. Bomag offers nothing in their manuals for taking apart the transmission assembly in the drum.
Does anyone know about the noise issue what it may be and how to tear down the transmission in the drum. The noise starts after the machine has run for,
about 15 minutes enough time for the hydraulic fluid to heat up when that happens the drum seems to drag down also causing the machine engine to drop power.
mg2361
Pennsylvania
Equipment Mechanic
While I am not familiar with your machine, I can look at in our manual library to see if I can find anything. Your serial number is incorrect and too long for Bomag. Maybe post a picture of the serial plate so I can access the correct manual.
mg2361
Pennsylvania
Equipment Mechanic
Sorry, I unfortunately do not have a manual for that serial number. Only for higher serial numbers. Even the newer serial number manuals have nothing on the transmission that I can find.
Columbia SC
We found another number stamped into the machine which maybe a serial number
101 590 30 1005
If possible at least is there a way to find out who the manufacture is for the drum roller if not Bomag.
Then I could try and contact them directly.
mg2361
Pennsylvania
Equipment Mechanic
