Hello.
I've got a 2014 T34/20 trailer lift that started working slowly then quit. I've replaced the fluid filter, the fluid and even installed a new pump. The electric motor runs perfectly. When I remove the main output hose it squirts copious amounts of fluid. When I cap it I get no pressure. I've cleaned and checked all the check valves. I can't even get the outriggers to come down or up. It has 350 hours on it. It's as if it's circulating the fluid around but not building pressure. Can't even get pressure from the manual pump backup. Ideas? TIA!
