2015 Hino 258 RPM run away
redline808
Hawaii
Okay, I have a problem with my 2015 Hino 258 rollback tow truck. Issue started yesterday. When I start up the truck after about a minute of idle the engine RPM instantly goes to 3000, no way of stopping it, I just need to turn the key off. It only does this when in neutral. Another example is I'm driving, I'll come to a stop and almost right after I shift into neutral the RPM runs away. It does not matter if the parking brake is on or off. Note; a few days before the issue started, I had the DEF system deleted. I scanned the truck and I get a P1133 Malfunction of operational accelerator sensor (high)
Anyone ever have this problem? any advise. There is no dealer in my area.
Thanks!
redline808
Hawaii
I'm wondering if anybody has had this happen to them because of a faulty accelerator pedal assembly? I'd hate to change of $500 pedal and that not fix the problem
Coaldust
North of the 60
That’s rare to have a pedal position sensor fail like that. They have a idle verification feature that’s supposed to prevent that. I would call your dealer or contact Hino directly and see if there is a recall or at least a TSB or something available regarding the issue. That’s a serious safety concern.
Coaldust
North of the 60
You watch Archer? The first few seasons are good brainless entertainment.
Coaldust
North of the 60
I suppose the delete could be related. Good point.
It could just be a coincidence. How many hours did it run after the delete before it started idling weird?
Coaldust
North of the 60
A quick duck duck go search for “Hino 258 high idle” results in numerous reports of what the OP describes. Wiring harness corrosion near the fuse box is a common theme.
redline808
Hawaii
Interesting. What does your delete guy say about it?
Originally they said just unplug the EGR and the DEF pump. They were probably assuming that all the associated equipment had been removed as most do.... But it was all left in place and a new exhaust was routed around it. That being said, they said to unplug everything associated with the deleted equipment. I did and just did a 200 mile trip without issue. Seems that a sensor was feeding information back to the ecu and the ecu didn't know how to handle it.
Coaldust
North of the 60
Thanks for the update. Glad you figured it out. I’m interested to find out if your fuel economy increases.
MikeMike258
Florida
Hi redline808 do you know what all you unplugged? If you don’t mind me asking I’m having the same problem right now
