Delmer is explaining right. But just to put it another way, if the gland is spinning with the nut, you can prevent that by extending the cylinder all the way out so that the piston is pressing tightly against the gland. Another thing to be careful of is that once the retainer ring is removed from inside the cylinder end, the end of the cylinder must be clean extremely well including the ring groove so that the orange filler ring fits in well enough to pull out the piston. If the orange ring is damaged or missing, you can fill the groove with body filler and clean it back out immediately after the piston is removed. I've done it this way 3 or 4 times with great success. After the groove is cleaned out of dirt and rust, I put a little oil in the groove with my finger to prevent the body filler from sticking too tightly to the metal. I have never used the orange ring during reassembly as I find that the seals hook on it and prevents the piston from entering.
