Chrisso
Removing a hoist cylinder, needs resealing.
Upper mount near fell appart.
Lower mounts usually fall apart but this one is stuck on good.
Book calls for 3 jaw puller and a 2 other bit's that aren't available. So I made a plate up with three holes to essentially grip the cylinder from behind with nuts on bolts and pull the cylinder off the bearing that way. Used a large 3 jaw puller pulling the plate against the bit attached to the machine. Cylinder doesn't look close to moving.
Upgraded to a 'smallish' cylinder, maybe 20 ton, applied heat, flogged it with a sledge hammer, the pulling force bent the plate and stretched the bolts.
Going out there tomorrow with longer and higher tensile bolts and a 30 ton cylinder. Any bigger cylinder and I don't think I'll get it in there.
Anyone else had this trouble? The "three jaw puller" suggests the interference fit between bearing and cylinder shouldn't be that tight.
Didn't take any pictures while out there but this is what I'm talking about...
