75g slow sometimes
Newibiner
Wisconsin
This machine some of the time won’t achieve max pump flow, engine performance is fine. Then just like a switch gets flipped and everything is back to normal.
Once everything is back to normal it is fine for the day.
Serial 1FF075GXJEJ015299
mg2361
Pennsylvania
Equipment Mechanic
All functions or certain functions? Did it star with certain functions and progress to all functions? Does it happen right after start up, or do you need to run it a while? Have any pressures been checked?
I would suggest pulling both the pilot and hydraulic filters and inspect them for debris.
Newibiner
Wisconsin
Happens at start up. Once it returns to normal it’s fine for the day, or week. Swing and the blade operate normally. Just travel and any excavation function are affected.
Newibiner
Wisconsin
I cut the filters open and did not find any of the expensive glitter. So that’s good. Pilot pressure is at 600 psi. Pumps pressure is around 4786 with a stalled track.
Newibiner
Wisconsin
Gave up and took the machine to the dealer. They can’t find the issue either. Waiting to hear back from Deere with dtac
