Hey,Resistance you feel is in the foot air valve ( probably E6). On the cluster ( that’s where air pusher bolts to master cylinder) there’s usually indicator rod - when air drum pushes the master cylinder you should see thin rod moving in and out. If it doesn’t - your problem is in the air half of the system. Does machine building up the air pressure? Usually gauge would have green field and say “drive”.
Hey, Thank you for responding. I didn't read what you had posted accidentally earlier. How do I go about testing the solenoid? How do I access the solenoid and the micro switch? I enjoy mechanics but my dad was always at the bar growing up so I'm not the best but I really like to try so thank you for all the help.Does the brake pedals move when you push on them? Is there brake fluid in the brake reservoir, on right side of machine near engine and transmission mounting area? On the transmission problem there could be two issues, the shift solenoid in trans control valve for first gear or the micro switch in the FnR shifter switch.
Thank you! This will make everything much easier.View attachment 210644TheView attachment 210645 solenoids are under item number 2 and you can check them with an ohm meter. They should all ohm out the same within 10-15 ohms anyway. Item #4 are the solenoids you are looking for.
No problem: let me know what your reading are on the solenoids please.Thank you! This will make everything much easier.
4 of the 5 solenoids were at .08-.09. But the 3rd one down didn't read at all. Which makes sense because I think that would be the one that controls 2nd gear. Because the very top one I don't know what would do but the other 4 seem like they would control the individual gears and that makes sense because it doesn't shift to 2nd. Are all the solenoids the same? I thought of pulling a different one out and putting in place to test it. Titan Machinery said the solenoid is $850 and that seems ridiculous to me. DOES ANYONE KNOW OF A BETTER PRICE?No problem: let me know what your reading are on the solenoids please.
Hey Coy,Does the brake pedals move when you push on them? Is there brake fluid in the brake reservoir, on right side of machine near engine and transmission mounting area? On the transmission problem there could be two issues, the shift solenoid in trans control valve for first gear or the micro switch in the FnR shifter switch.
TVA,Also it might be wiring problem and not solenoid it self - verify before buying.
If there was no break fluid it means something was leaking! Another problem when system is empty for a long time - everything gets rusty because break fluid is hygroscopic and attract moisture.
So even if your air side is working ( which you haven’t verify yet) after you fill system with break fluid components would start leaking one by one!
