emarr
Hi, i have a 850c II, and it wont move front or forward with joystick, but if i use manually the pcp valves on the front and back pump the ones under the cabin then the track move, if i use the pcp that are on each final drive they dont do anything, now what i do know is that somebody put 12v directly to does pcp valve on the final drives, what i have read is that does pcp may be damage because the only use a max of 5v, is there a way that i can test does pcp to see if they are damage?
