85XT Case Skid steer lift arm's going up with problems..
BCBandit
Chicago
I have a 85XT Case skid steer that I just joined this forum 2 weeks ago to fix a Engine to hydraulic pump coupling issue.. That was all done and perfect but now..
OR even before the coupling went , I'm having a problem with the arms lifting.. You can hear it in the engine going up, You can hear the engine working harder.. Not down, Or driving or anything else.. Just up seems to Aerate the hydraulic system, to add foam to the hydraulic oil .?
System was flushed a few times however did notice metal shaving in one of the buckets that was sucked out of the tank.?
Also just got a rebuilt front hydraulic Pump and that did not fix the problem with the lift arms lifting..
Any ideas as to ideas to try to get arms lifting again with out guessing at parts to throw at it.. lol ..
Like I said it will zip around the yard or lower the arms and the engine just ideas normally.. But up and you can hear a little bogging down in the motor.. Thx.. River Grove IL BCB...
