863 fuel tank access
acasey1433
Dayton, ohio
bobcat
u have to lift the bucket all the way up there are to cab bolts on the inside corners. remove them bolts and lift the cab. might take two people. Once it is all the way up it will lock in with shock. drop the safety arm over the bucket boom cylinder. give me a call tommorow at 937-684-6621 i just had to do the same thing yesterday that your needing to do.thanks
toomacho
Dawsonville GA
High School Teacher
Yep, lift the cab crawl in and reach to the left center of the machine ( Right center from operators view) and you should feel it. Get someone to shake the line from the back of the engine and you should be able to get to it.
it's a real PITA but can be done.
Hope this helps
