rditz
folks,
I am also having clutch problems. Mine is bound and I also cannot get into gear.
I have taken the inspection cover off as well as the clutch cover. this gave me a lot more visibility to what was wrong.
first thing I noticed was that the clutch lever was bent and upon further inspection saw that the joint was severly cracked. I have attached a doc that i have circled what i think I need.
second thing i found was that one of the 4 spring loaded studs that the pressure plate rides on was broken off and the spring was broken and jammed. I have attached a doc, again circling what i think i need.
Finally, the clutch support assembly has a crack in it near where the clutch rod connects to the lever to work the clutch, I am assuming from extreme pressure from operators past trying to get the clutch to work.
Couple of questions... how readily available are the parts for these clutches?? can I still order through Cat?? I also assume that If i replace the springs and pins, i should do all 4 in order to have the same resistance/spring rate or tension all the way around. can the clutch support assemble be welded?? or do I have to have it specially welded??
thoughts/comments are appreciated...
eitherway, i guess this clutch is coming out.
rod
rod
