YesYou mean 60a, which filters?
Any of them very hard for me to find info on this machine any info would be greatly appreciated
60a1-499960A-prefix machine falls into 3 groups for ordering parts.
60A1-4999, 5000-8412, and 8413-Up.
Which group does your machine fall into.?
Filters may be common (haven't looked) but it would pay to know what we are dealing with.
LeverIs your machine lever or peddle steer?
Nick
thank youIs your machine lever or peddle steer?
Nick
Thank you for th no sirThis is what appears for 60A1-4999.
Engine oil: 7M-3800 + 2 x gasket 5M-9999.
Fuel: 9H-4729 + gasket 5M-0954.
Fuel Screen (if damaged) located in glass bowl under fuel transfer pump 9M-5451 + gasket 9H-2770.
Air: Primary 8M-8048. Secondary 8M-8047. May require gasket 4M-1485.
Transmission: 7M-3800 + Seal 5F-3144.
Steering Clutch Booster: 7M-3800 + Seal 5F-3144.
Hydraulics there are various options. It might require an accurate Serial Number or open up the filter housing on your particular machine and see what's inside as you prefer.
I haven't checked any of the above for updated Part Numbers.
As far as I can see they are correct but I wouldn't guarantee it 100%.
As I said above you really need to get yourself a Parts Manual, and sooner rather than later.
60a13279OK, so the Serial number is now confirmed as 60A13729, only a dozen or so machines before the production of the 60A model ended at 60A13741.
So that changes everything............
The Parts Manual is this one covering machines from S/N 60A8413 to the last machine built.
I cant see anyting available used.
Cat Publications - https://catpublications.com/
or https://www.servicemanualpro.com/?page=Products&searchbox=60A13729 appear to be the only two alternatives to get hold of one.
