A25c no gear select
PHDiesel
Brisbane
Hi all,
Have a volvo A25C. Truck will not select any gears forward or reverse, and the alarm buzzer sounds when you try and select a gear. Contronic display unit also not working so am unable to retrieve a code
Cheers
SlatcoAu
Edmonton, Alberta
Hmm, could be a few things. I would check and make sure that you are building full air pressure on your brake system prior to putting in gear. Another thing to check would be the rpm range when attempting to put it in gear. If you are over 900rpm it won't go into gear.
PHDiesel
Brisbane
I am wondering if it is linked to the display unit not having any power, because I also found that the ECU2 which provides information to the display also has no power.
Transmission ecu has 24v supply in pins 2, 20, 16 and 17, and the gear selector has power going in and out
PHDiesel
Brisbane
Got the contronic working, found one of the fuse holders that supplies power to ECU2 loose. Service display is showing transm.comm ER
SlatcoAu
Edmonton, Alberta
Oh boy. Been there in the past. Hope you are not going to suffer the same fate.....
GuzBR123
Brasil
Hi,
allowed the problem?
Does anyone have the wiring diagram for the a25c, on the a35 I was able to manually shift gears.
