aftermarket grade control
dialedin
Ontario
farmer
I've got a 2008 cx80 case excavator and i've got a bunch of ditching to do; is there any system that anyone can recommend that i could setup on my machine that will give me depth and grade control? I've been having a second guy take rod readings whille we trench but its taking forever and awful time consuming. any guidance would be great. Thanks
GEORGIOS198217
Greece
I am looking for a system of 2d with just slope control to have the opportunity after some years to do it 3d. The most i need some information for this system because I don’t know much.i am located in Europe
Georgia Iron
USA - Georgia
Concrete building slab and grading contractor
Any basic 2d machine control will do slope off a laser. You need a laser that will slope but it must be in a straight line or you will need to move it every time the angle moves.
3d machine control uses a total station with control points. You either make them or a surveyor sets them for you. It typically works off a prism on only one side of the blade using slope, and rotation sensors to control the rest of the blade.
Lasers are more accurate and run off of 2 sensors one on each side of the blade.
A machine control panel activates a custom made valve that attempts to keep the sensors on the beam.
