another hitachi ex120 question...
machine
toronto ontario canada
the fresh air filter is under the rear vents. to remove the cover press the ends in
and lift up. look down at filter and observe which way the arrow is pointing so you put it in the same way. take hold of the handle and lift it out.
there is a recirculation filter that is under the rear deck. pull on the two grips at each end to remove it. you may have to move the seat forward for more room.
