JfitzCat
I have a 304e2 with about 2300hrs. Bought used from cat at 2000hrs. I’m coming up on my 3rd swing gear and bearing grease (every 100hrs) and debating on what grease to use. I would typically not use moly grease on ball bearings, but this is a very slow moving bearing. Manual says to use 5% moly, but that’s most likely because they know for most people it’s too much to ask they use 2 kinds of grease on the machine. Easier to recommend the same kind of grease throughout. But I want to use what’s best.
For the last 2 greasings I’ve been using Chevron Delo 5% moly. It’s lithium based grease. I have some red non moly lithium I could use. Or I’m thinking of getting a tube of TRC 880 crown & Chassis red grease. Seems like the perfect grease for something like a swing bearing. Based on the charts it is compatible with what I’ve been using. It’s a calcium hydro base which is compatible with the lithium complex I’ve been using.
What do you guys think? Just keep using my 5% moly and keep it simple like cat recommends, or get a tube of TRC 880 and keep it in a separate gun to use just for this. I do have an extra gun. I doubt it would ever fail even with the moly grease given that I’m consistent with my greasings, but I like to overthink everything.
