bobcat 335 excavator instrument panel removal ?
L&W
Connecticut
Went to a job my 335(2007, keyed ignition, same cab as more common 331 ) was on to remove it after job completion. The engine turned over but wouldn't start. Long story short, all relays and fuses good. The lcd screen has been out for a while and didn't feel like spending 1400$ since I was not using machine all that much. Ordered new panel and figured I would take the old one out. Bobcat said just release the clips holding it in, sounded like no big deal. I can't find where they are ! seems like they are on the sides because i ca pull the top and bottom out by hand. Don't know if the clips are on the panel or the console, push, pull or what action is required, Yikes. Also want to remove and replace the ignition switch but the retaining nut is on the outside and you need to get it from inside the console,its a solid molded pp=art with no means of access.Foigured I would grt it out one the panel came out . Thanx
vlamanna23
NY
Did you ever figure out how to remove the control panel? I am having the same issue and don't want to break something...
Regards,
Vince
