JakeKraft
Hello again. My 2007 bobcat 435 has seemed like it has weak travel since I have owned it. It travels pretty straight, but struggles to turn in high or low. You can feel it shift from low to high, so I dont think its stuck in high. With the tracks in the air it free spins quickly, and it travels fast going down hill. The linkages from the travel controls all seem very clean and tight, so it does seem like a hydraulic issue somewhere. My manifold pressure is 3500 PSI at half throttle. I did put a gauge on the line feeding the track motor and it shows 2000-2500 PSI at full travel. Should it be higher? What other tests should I do or look at? THank you in advance for any help!
Jake
Jake
