Bobcat 773G RH thumb toggle not engaging
Pineyman
South Jersey
So I have a 2002 773G which run and drives great. Unfortunately the auxiliary hydraulics seems to only work when I pull the trigger on the RH stick. When I try and toggle the thumb switch on the RH stick nothing happens at all, no engine groan or RPM change when i push it in either direction. I am not getting any codes showing up. I also traced the wires and nothing seems to be corroded or broken. I have plenty of hydraulic oil on board and all other hydraulic functions work great. Any ideas on how I might resolve this?
Pineyman
South Jersey
Update, I found a blown 25A fuse and replaced, but it still will not function. I also took off one of the spool solenoid valves and tried to get it to magnetize but it did not seem to be getting any power to it.
Greg Burtoni
Wisconsin
Did you ever figure out the problem? I recently purchased a 2002 773 and i am experiencing the exact same issue you were having.
tschla56
Texas
I have the same problem with the right toggle not working
Did you get this fixed. I am experiencing the same problem.
tschla56
Texas
Do anybody have an answer to why this right toggle is not working?
KOBE STEEL
Hello Sir,
If possible could you provide some more details so that myself or someone else can try and be of help. Could you start with the machine serial number and a detailed description of the problem such as when the fault started to occur, any other functions affected, any fault codes displayed and what functions do appear to be working correctly. Give as much details in your reply as you possibly can and we will try and help you resolve the issue.
Best regards
