RickT73
hello looking for input i have an 04 Bomag diesel plate PR 65/52D-3 pick up at an auction faily cheap Runs great But will only go forward .
it has the thumb forward and reverse switch so far this is what i have checked hydraulic fluid ok, loosened the fittings at thumb control under switch seams to be getting fluid , took body control switch off and inspected it put 4lb air and worked switches seems to be functional not sure which is pressure but seams to be going thru the other ports ??
i've used it once to compact a footing just forward and would like to get the reverse fixed if possible.
any knowledge is appreciated
