Can auxiliary hydraulics get too high on CAT 259D
Thanks for that Tid Bit. Was wondering if you remember where you bought you crossover relief from, Brand , Type, not sure what brand of plow you have. Thanks
Simon C
I bought the pressure relief right from Summit for around 45 dollars.
The plow is a Meyers copy from Mass Made by Curtis and I specifically wanted a blade tip over type, as I plow a lot of gravel.
I sliced a 2” black iron pipe and fitted it over the cutting edge.
The pressure relief block I bought came preset at I think 1250 psi but I have played with it a few times as you can just ease up to something and trip it over to the other side.
Not sure i‘d plow without one as you have way more pushing power than a truck.
