I have a Zenith L63 Carb which needs to be replaced but I have some questions when looking at the replacement carbs.
1st - the 2 Zenith carbs I found look exactly like the one I have but they have no model numbers stamped on them or tagged.
Should I buy a carb based on the same manufacturer and looks only??
2nd - the 2 carbs I am looking at have 1 major difference and I was wondering what people thought about the differences. 1 carb has plug which is where the main jet is. The 2nd carb has a valve which you can adjust the main jet.
Which one is better to use??
Additional info which confusses me a bit:
The owners manual for the engine shows the carb to be used as the non-adjustable main jet (plug at the bowl end). But the engine has the adjustable type (valve at the bowl end) which was working OK for the past 3 years until I broke it. Should I lean towards what I have and worked or what the manual states?
Wisconsin engine model #VH4D
See attached pics of the 2 carbs
Thanks for any help
Leckster
Thanks for any help
Leckster
