Case 580 super m
250quality
Wyevale ON
Thanks for the add to the forum.
Recently my Case 580 super M series 3 has no foot throttle response. Has a caution light on the dash and a symbol I don’t recognize. Anyone know what this symbol means?
gggraham
London Ontario Canada
Licensed Heavy Duty Equipment Mechanic
That is your foot throttle sensitivity. So say you are crossing a rough site at half throttle should you hit a bump and your foot bounces up and down on the throttle at the low setting it delays how quickly it will throttle up or down.
Coy Lancaster
Arkansas
service tech
You'll probably need to have your throttle control recalibrated, if not replaced.
250quality
Wyevale ON
Turned out 4 wires in the harness running beside the hydraulic filter wore through. Repaired and worked perfect until today. Now has a broken wire symbol on the dash and is in limp mode. Checked all previos broken wires and all are good. Looked everywhere for the issue but probably going to have to bow down and get Case here.
