national1
i have a case 621b with zf trans and shifter non auto shift the first problem i am having is the loader will not go into 4th gear the next problem i have is that 1-2 work fine forward reverse , you shift to third it goes then when you shift to reverse it will not go back into third , turn the machine off and on again and it will go into third gear. now for the big problem was driving the loader and trans stopped working checked fuse blown replaced fuse still no luck key turns but engine will not crank (if you jump the solonid it starts) the computer is pluged in the conections under the cab are clean have not checked the grounds yet any ideas??????
