Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
helpin' a buddy pull his engine.....does the shuttle and engine all come out at once?....then do you have to strip the shuttle to get it off the block?
Leave the convertor behind - undo flex-plate bolts from behind plate on bellhousing near where engine breather hose is located, just under engine cranking tool hole. (15mm socket req)
Then undo bolts around convertor.
The plumbing going to convertor will hold it in place - a tie down strap going through floor plates & attatched to grab rail could assist - if you want to remove convertor transmission & hyd oil oils will need to be drained
