Quki22
Going to replace my AC accumulator on my CAT 277C MTL (JWF01714) and was curious if anyone knows how many lbs of 134a is required for a full charge.
2.8 pounds of R134a.Going to replace my AC accumulator on my CAT 277C MTL (JWF01714) and was curious if anyone knows how many lbs of 134a is required for a full charge.
For reference, this is a tag I found on the internet for a 259DHello Cmark,
It’s a little beat up, but based on other photos of tags I found on the internet I am pretty sure this is showing 0.60kg also the part number can be seen in the lower right corner of the tag. View attachment 281989
1 fl oz of PAG oil is required per component if you go into any of the following - accumulator, condenser, receiver/dryer, or 3 fl oz if you replace the evaporator.
Hey Nige,2.8 pounds of R134a.
