I have a Cat 289c2 about 1100 hours on it. S/N CAT0289CTRTD01496.
Was in it this morning and the 1 alert light came on flashing with the 10 in amber showing dirty air filter. Replaced air filters inner and outer. Fired up machine and just lifted a pallet to a loft in my building, shut machine down, unloaded, got back in machine and same lights came on. Bucket will not go up, I have tilt and down.
I checked codes via the old style left hand monitor and have the following codes, not sure about active or stored as it was getting pretty late and the screen fails to tell you the system mode you are in.
2475-3 Right joystick voltage high on forward back
2477-3 Right joystick voltage high on left right
1251-4 Alternator R terminal Voltage low
96-3 Fuel level sensor Voltage High
and error codes
E876-1
E875-1
E875-2
E391-1
I think the top 3 are voltage and that could be from having key switch on and off playing with stuff all day today E391-1 is the air flow.
I have checked voltage to the blue and black wires at the air flow sensor, blue was 12.6 or so with engine off. Black shows good ground with my power probe. So I am not sure why that code comes up any time I attempt to lift the bucket.
With machine running I can go forward and back, tilt bucket no lights until I attempt to raise the bucket and then the air cleaner lights pop on.
I'm awful on electrical issues. It sounds to me like the right joystick has a problem but before I spend like $1600 on a new one I figured I would ask if there is anything I should be looking into first.
I also went into mode 6 and tested the joysticks. The left one the percentages go up and down very smoothly. The right one, on tilt function it seems to work okay but the percentages are low, like under 10 percent. On raise and lower I have 0 on lower and raise goes straight to 100 and throws the error light.
Thank you for any help its greatly appreciated
and error codes
E876-1
E875-1
E875-2
E391-1
