Cat 299c 950hrs # JSPO2170
Hello, Having issues with my machine. If im moving a load from A-B it will loose speed just slows down gradually, Norm or rabbit mode. If i back joystick back to center ( stop) & go back into it it will hold till I move joystick again to turn etc. Same if i have to use rabbit mode i will need to stop machine start going forward then hit rabbit it seems to have good take off speed then will slow down ( random distances ) when I need change in any direction ...Everything else seems to work fine boom/bucket etc .... Any help of anyone out there maybe has same issues or can help would be very appreciated! Thank you !
Things that ive checked so far :
1- Speed sensor wires around pumps seem to look ok no obvious damage to wires
2- Changed hydrylic filter again ( just changed hydro fluid 50hrs ago)
3- poured old hydro fluid out old filter in clear container looking for any metal or brass particles ( found Nothing was clean)
4- Had a tech come out check for codes ( (no codes) did check PSI 42 .. he could not check flow tho ... & Joystick was communicating seemed to be ok
5 - Machine is pretty well maintained oils filter etc
