I would make sure you install the quick release handles back on the door. I've had to remove my door several times in order to get out. It's when I run out of fuel. I trying to finish a job on my property, and always think I can work a few more minutes until I run back to the fuel tank, and then I'll take the machine on a slant and the fuel shifts in the tank and I'm out of gas. I'll have a Root rake on and usually full of stumps or logs and the grapple and arms are stuck in the air. If I did not have the quick release handles on, I would be stuck in cab, I always make sure I collect all my pieces on the ground before I move the machine.
