Post the machine Serial Number and it ought to be possible to find a parts breakdown.I can’t find the parts on cat it is a 2007 303.5 anyone have the parts break down of this
Does your A/C setup look something like this.? Post a photo if you are not sure.It was the fan belt but what happened is the pulley tensioner came off the compressor belt and broke both belts. I managed to get the fan belt back on but the pulley tensioner is all messed up I do t know how it goes together since parts are missing.
Do you mean are there any piece parts available for the pulley assembly.? If so the answer is no, it’s only sold complete.Is there any way to see how that pulley goes together a closer look at the assembly?
When you found the pulley was it missing the bolt and the other fittings.?I just don’t know how to put it together. I have the pulley (found it) but missing washers and bolt assembly
