D3DaveC
My 2005 315CL engine won't shut off when I turn the key off so I pulled the rod back by hand and the engine shut down. When I shut the key off the engine is still idling, then will speed up, then back to idle. Seems to me the solenoid is trying to pull the rod back to shut the fuel but then fails and releases. I tried to adjust the rod a little(not knowing how much I can do this) but it's still the same. Should I keep adjusting the rod to shorten it or do I have to replace the solenoid, part# 227-1046, ref# 18 on page 71 of parts book. Maybe while engine is running if that solenoid is actually working and trying to pull the rod back I can keep adjusting the rod until it does shut the engine off? Will anything be damaged if key is off and engine is running(with all this computer stuff)? Thanks
