CAT 943, bad hydraulic vibration
Hi all, I am new here and I hope someone can answer my question(s).
I have a 86 943, which is an awesome machine, but last month I got is semi-stuck in the mud, which has left me with a bad vibration. Let me explain:
I was working around my pond and got the front end a little stuck in the muck (bucket wouldn't push me out), so I raised the loader boom all the way up and left it running (5 mins) while I got some 6x6's. While I got the 6x6's I saw a huge puff of smoke from the tractor, so I ran over and shut it off. I looked at where the smoke was coming from and it melted the plastic hyd measuring window on the hydraulic reservoir.
I got that fixed and filled the reservoir back up with AW32 oil and when I tried to run the loader, it made a really bad vibration noise coming from the reservoir. The pump sound fine.
It does not vibrate the first 30 seconds after I start it or when the throttle is less 20% WOT. Sound kinda like something is preventing the flow. I have ordered a maintenance manual because I do not know where the filter is. Any ideas?
Thanks in advance
Thanks in advance
