Chevy C60 OBD Connector?
Pig
NE Pennsylvania
I have a 1988 366ci Chevrolet C60 that we've been using on the farm. Great dump truck, that's still in decent condition.
Recently the CHECK ENGINE LIGHT has come on, and I am not sure where or how to get the code to display. I presume this will work by blinking CEL, if only I knew how to get it to display.
I certainly can't find an OBD1 connector. There is a three prong socket at the fuse box (that looks a little like a household 110V socket).
Does anyone know how to read the CHECK ENGINE CODE for a 1988 Chevy C60??
Old Doug
Mo
There should be a connecter under the dash you cross the 2 far right upper row together while the switch is in the run position.Is it not running right?
  • Like
Reactions: Pig
Pig
NE Pennsylvania
Looked again, and can't find a OBD/ALDL connector. :(
I mean, the truck works okay, but the Check Engine Light being on IS kind of annoying!
John C.
I don't remember any OBD connections in 1988. The one make that sticks in my mind was Ford with their EEC V systems and no OBD until the mid nineties.
  • Like
Reactions: Pig
Pig
NE Pennsylvania
Well, there's a Check Engine Light, that would indicate that it's sensing SOMETHING wrong. I'd just like to find out what it is! :)
djhutt
Slate Hill NY
I had an 87 c60 and an 86 g30 that if I remember correctly had an orange 8 or 10 pin inline connector under the hood on the driverside fender that I jumped the end 2 terminals and it would flash codes with the check engine light
Pig
NE Pennsylvania
Well, I looked under the hood, and there's no OBD/ALDL connector there either.
Maybe it's time to look at this from a different angle: as I can't seem to find out what the error code is that is throwing the Check Engine light, maybe I should investigate ALL possible reasons for it. I mean, there can't be THAT many things that will trigger the CEL, surely!
Does anyone know what to look for? What are ALL the possible reasons for a CHECK ENGINE LIGHT on a 1988, 5.7l, Chevrolet C60???
Axle
Ontario Canada
electronics tech
That 3-prong plug on the fuseblock is for a 2 pin flasher on c10/20/30's. Thats about all I can accurately say about it.
What kind of fuel control is on an 1988 c60? carb? tbi? fuel injection?
HEI still used in those? (has a vacuum can) Or a distributor with a single plug in connector on the base?
Not that I'll be much help, but if anything is similar to the light duties, might be able to come up with some ideas.
4x4ford
Las Vegas Nevada
aunts on the strip Currently drive a 1951 chevy pa
I’m really thinking that with a carb that there really isn’t much of anything to set a check engine maybe check the temp sensor and oil pressure sending unit to make sure there isn’t a broken wire not really anything to be computer controlled on that
I can't help much either, all I know's OBDII was required in 96, but that might be different for heavy duty also. Best guess is to compare it to the similarly equipped pickup and look up how to read the codes on those. Maybe find the ECM and find the pickups that used that also?
Vacuum leaks were a big thing back in those days. I never knew GM though, so I don't know how much they relied on vacuum.
Axle
Ontario Canada
electronics tech
If its got a carb the only thing it might have is some version of Electronic Spark Control, if your distributor has a vacuum can, it won't even have that, and was probably converted to a standalone HEI.
On light duties, pre-obd, w/esc the module was bolted above the glove box, it might have given up the ghost and is what is triggering the light.
If you elect to remove this box (assuming it is esc, and assuming it has a stand-alone distributor) you might lose powert to the distributor, if so, just got to back track the switched power feed for the esc (large red wire) and find the inline connector underhood. (usually in the distributor area in the firewall harness, might be loomed up)
Disconnect, and connect the switched feed directly to the distributor BAT terminal. Assuming no previous hackery, the in-line connector plugs right into the distributor. Presto, no more esc, and if you unplug the esc, no more related dash lights. I'll emphasise again this is based on older light duty trucks, but it may give you some extra ideas of what it is you might be looking at.
