old-iron-habit
- Joined
- Nov 22, 2012
- Messages
- 4,233
- Location
- Moose Lake, MN
- Occupation
- Retired Cons't. Supt./Hospitals
Just a comment on 53 series water leaks. This last summer we had a water leak in a 4-53 that powers a lumber edger at our local antique tractor show. The water had been drained every winter for the last 20 years that we know about, and who knows how long before that. It has not had and additives against corrosion in that time. Turns out the block rusted thru at the bottom of the upper section of the water jacket and into the top of the ports passages. When shut off it ran into the oil. If it had antifreeze in it year around it would not have needed a block replacement. Just one more oddball place to leak. When the pan was off, the water could be seen entering the offending cylinder from the port.
