Toddgarage
- Joined
- Jun 13, 2022
- Messages
- 80
- Location
- S.E. Michigan
- Occupation
- Construction, welding/fabrication, operator
First post, long time lurker and I want to thank you all in advance for your advice!
Deere 50D (gen1), 6000hrs, engine runs strong, and machine runs strong until a few weeks ago. The machine sees regular use and some abuse, but on average well maintained. We noticed the rotate function was slow and the forward/reverse travel speeds were also slow at all engine speeds. (tracking forward, moving the throttle up or down will not change the travel speed, the engine does not struggle either.)
A few weeks pass and the machine is sitting in the yard. Another guy mentioned the problem went away for a few days but has returned. I use it to smash the dumpster now and the same slow functions are present. Even the boom/jib/bucket seem slow at all engine speeds. One guy explained it "its like the main hydraulic pump doesn't swash and ramp up"
Fluid level correct, Hitachi oil (zinc free) always used, no leaks and no visible damage. No pressure readings yet. I want to carefully address the repair before applying the expensive parts cannon at it.
plan is:
Inspect suction strainer. Inspect main filter. Inspect pilot filter. Check fuses and relays.
Let's say those all look good, where would you guys start? Is there a priority valve? Hidden strainer filters? Electric solenoid for a main control valve to activate the main hydraulic pump?
Cheers Guys and thank you. (i'll be at the machine later this week, so specific questions will take me a day or 2.)
plan is:
