k_kindig11
I believe the starter went out on my Unit crane. Motor is a Detroit Diesel 3-71, model 3055-C. I took the cables off and got the three bolts out that hold the starter in place. When I try to slide the starter back and out of the pocket where it engages with the flywheel, it doesn't seem to have enough room to get it out. Does anyone know if other parts need to come off the motor to get the starter out or should the starter be able to slide out (tight, but come out) without taking anything else off? I have attached a picture of a motor I found online as I forgot to take a picture and it's dark out now, but you can see there isn't much room to slide it out since the starter has a domed portion that is inside the pocket in the motor where it engages with the flywheel. There is a filter housing below the starter that keeps it from going down and a water pump housing on the back side. I've tried tilting as i put back put can't seem to get it. Any help would be GREATLY appreciated. I just want to make sure I'm on the right path without making a bunch of unnecessary work. Thanks
