Discouraged!
Donny bowman
Western nc
I have a 864 bobcat skidsteer.
It sat all winter on a job and I have recently (the past 6-7 weeks) been back on the job trying to complete it. The issue us my skidsteer won't crank. It puts out tons of black smoke when turning it over. When arriving back on the job in April I cranked it several times and after laying on the starter it would eventually start and all the black smoke would clear up and it would run great. Now it won't start back up even after new injectors, air filter a d fuel filter. Even with a shot of ether. Anything else I can check? Thanks
Donny bowman
Western nc
I haven't messed with the timing. It did start eventually laying on the starter ,but not at all now.
I'll try pulling the solenoid tomorrow.
Thanks for the reply!
Coaldust
North of the 60
Nobody has mentioned glow plugs, yet.
Donny Bowman, welcome to the HEF. Good to have you. Feel free the hang out and chat with us. Head over to the new member introduction area and tell us about your operation.
Aux. hyd's engaged and lack of glow plugs can cause no start and black smoke. Not sure what engine you have but my 94 skid steer with an indirect injection Kubota won't start on an 80F day without glow plugs. Once it's warm it starts without them. Needs about 15-20 secs. minimum. Over a minute when it's below freezing. Ether isn't recommended for Kubota's but a tiny shot without the glow plugs could help diagnose a glow plug problem. Putting it to full throttle can help with starting too. As soon as it's running on its own lower back to idle.
IceHole
AK
You say it won't crank... you meaning it's cranking but won't start?
kshansen
Central New York, USA
Good point I see those terms confusing for some people.
In my world "not cranking" means motor not turning over at all.
"Not starting" means engine is turning over with starter but will not run on it's own.
And to the point of glow plugs, if included, I know some engines will not even attempt to run unless they are used. If one or more are not working it may start but barley run for a long time.
BC Placer gold
Enderby, Bc Canada
Our Bobcat 743 was the same; needed the use of glow plugs for first firing of the day…
Basically the same engine except a bigger bore. 743 used a 36 HP V1702B and mine uses a 43 HP V1902B. I was scared I had the wrong engine in mine because someone at Kubota put a V1702B sticker on the intake manifold. A mechanic took a look and found where V1902B was stamped, I think on the injection pump. It would sure suck to have a one off lower HP engine in a new machine.
colson04
Delton, Michigan
Any updates Donny?
I have an old IDI Kubota in a Bobcat 743. (V1702) Like WelderDave said, it won't cold start at any ambient temperature without using the glow plugs. Once warm it will restart just fine. I have pretty well quit using the machine because I picked up a newer 753 with a DI V2203 Kubota that will kick off almost instantly when above freezing, and with just a little help from the glow plugs below freezing.
