TraxterMaster
Well I'm about done with that thing. I had engine smoking and stalling problem as soon as i touch any fonctions.
-Cleaned out the screen in the banjo fitting. (Help starting)
-Changed the fuel filter (didn't change anything)
-Checked the fuses, check harness(fix rpm sensor and solenoid wire)
-Replaced blown fuse. (didn't change anything)
-Swap solenoid harness(it moves slow and removes load on the engine when the fonction activated but reloads when the fonction goes back to neutral. "full swash" with out touching any commands)
-Swap solenoid location. (didn't change anything)
-Checked the spool valve(it seems stiff but I dont know how it should be, I need to stick 2 fingers and push with my 2 hands to move it up and down)
-Code 22 comes up on his DR.EX (abnormal pump control)
-Replaced the de-swash solenoid and still does the same.
-Checked the Angle sensor (the angle was showing 4.4-4.6 degrees and doesn't move. Tried to force to go full swash to recalibrate the sensor but could not reach 4.2volt maximum was 3.8volt. with the angle sensor of we could read voltage fine and the DR.EX was showing 0degrees to 26 degrees when turning the sensor.)
-DP sensor shows full flow
So now the question is how tight should that spool valve should be
