Jason Klassen
Hey everyone, I am looking for some more brain power with this problem.
Machine is a 120-2 with what I believe to be a 120-3 main control valve (mcv). This means it does not have the adjustable pressure regulator on top of the unloading valve like the -2. Its on the bottom instead.
According to the manual the differential pressure (dp) sensor needs to see 370 psi or more to signal the pump to run at minimum displacement while at idle. This 370 psi is set by the spool and spring in the unloading valve.
My DR.Zx shows that its making ~250 psi at idle and the angle of the pump is 6-7 degrees.
If I unplug a sensor and get the machine to run at max displacement (24 deg) at idle, the pressure increases to 480psi.
As far as I can tell this "base" pressure of 370 psi is set purely in a physical way by the unloading valve. There should be no sensors involved since the dp sensor is looking for 370 psi or more to set the pump angle to the minimum of 3 deg.
I have tried shimming the spring in the unloading valve to increase the pressure but it made no difference. There must be some sort of internal leak in the mcv. The pump is brand new inside so I don't expect it to be weak.
Any thoughts are apricated.
Jason
Jason
